Can't signin using ios app when connect to 4G network
  • 2 Replies
  • 3318 Views
BrucePearson
I can signin to the Arlo app when I'm connect via Wifi to my local network. Everything works fine there.
When I'm away from home and on the 4G network I can no longer signin. I see this message:
"Sorry; we are having trouble signing you in because of Internet connectivity issues. Do you want to try again?"
How do you fix this?
does the phone work on a wif system not your home based?
If it is only happening on 4G, then I might think there is a carrier issue ( not the Arlo system )
BrucePearson
Thanks for your help. I realized that I had run out of credit on my phone. I recharged and it now works perfectly!
