Can't send downloaded clips through text on ios
Our system has worked great. This morning I'm trying to text a downloaded clip from iphone and it will not send. I've restarted phone and also tried sending through ios imessage on macbook. It says not delivered? Any suggestions would be appreciated.
Hi @JoeShmo
I was not able to replicate this issue with iPhone 11 Pro Max & iOS 14.1 Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
