Can’t have 10 cameras in on schedule?
  • 1 Reply
  • 1462 Views
pjhallett
I’m making up my schedules up but have a annoying bug. I can make 1 block of 10 cameras and name it but the second block I can only put 9 cameras as if I put 10 when the schedule time comes around it does switch over to the next schedule. Any one have any ideas. I’ve reinstalled/ reset base unit / re done schedule. Nothing fixes the issue
steve_t
Master Master
Not sure what you're describing. Can you post a screenshot? When you populate the schedule, you populate it with modes. It shouldn't matter how many cameras are being used as long as the mode you want to use is correctly configured
