ARLO PRO GOING OFFLINE
2 Hubs with 2 cameras synced to each hub. Camera #4 on the 2nd Hub keeps dropping offline. It was located about 10 ft from the Hub. Re-synced several times with no luck, it keeps dropping offline. Any idea why this is happening when the other 3 cameras are operating perfectly?
This tends to happen due to interference. Try removing the camera and resync'ing it. If still no luck, try changing the channel your 2.4GHz wifi network runs on. Also, try swapping this camera for the other camera's position
