Can’t find power adapter for Base Station VMB4000r3
  • 2 Replies
  • 1382 Views
erval9
Is there a difference between VMB4000r3 and VMB4000 when it comes to power adapters? I’ve bought a couple on Amazon and Ebay that are labeled compatible with VMB4000 but don’t fit. I don’t see anywhere that they are compatible with VMB4000r3? Is there a difference? Or why don’t they fit on my Base Station? I’ve had to return them. Where can I get the right power adapter since I lost the original one when I moved.
No, there shouldn't be.
Can you post links to the Amazon ones that didn't fit?
The 4000 series base use a 12v DC power supply, at 1.5a, with center positive.
;  believe it is coaxial plug size 5.0/2.1mm OD/ID
