You do not need to find and set up the base again.
Once plugged into your extender just open your app and continue using as normal.
Try and use "Braund-plus" on your Wifi since you connected your Base there..
Try adding your base from LTE rather than WiFi also. That will bring you in from outside.
Does your extender use the router as the DHCP server? If so, I would think you should be able to see the base station and cameras in your app when you are on your home network, no matter which Wi-Fi SSID (or Ethernet port) you are using.
@Mbraund9881 wrote:
I will try this when I get back home. I tried it briefly but it said that the home base was offline. Maybe I didn’t let it sit long enough before I disconnected and tried to add it back to my account.
If you just physically moved the base and did not “remove” devices from your account before you moved the base, it should not need to be added back to your account.
Try and re-start your modem/router also
Lets not overcomplicate this.
Please read my initial reply in post 2 above.
Once you have your base set up you can move it anywhere in the world as long as it's connected to the internet.
Likewise you can access it from anywhere in the world provided you have internet access.
The name of your router or wifi SSID has nothing to do with it.
As you mentioned, when you moved the base to the extender you may not have waited long enough for it to power up fully and thus got the message.
If it's still not working then we can look at other fault finding steps.
@Mbraund9881 wrote:
Bingo. That’s what I’m going to do when I get home. My phone recognizes it as two completely different wireless points though. So I wasn’t sure that would solve my problem.
I don’t think the WiFi SSID difference matters, since the cameras all connect to the base using the unique base station SSID and the base station connects to your network via a cable connection to your router (network). I suspect it might matter that everything in your house is on the same TCP-IP subnet...one DHCP server for your entire house.
You were right! I brought it back into my house and it wouldn't connect there either. I held the reset button until the lights turned orange and then tried connecting again in my house. It did connect after it was reset. I took it out to the garage and connected it to Braund-plus WITHOUT removing the base and worked just fine. I didn't let it sit long enough the first time. Thanks everyone!!!!
