Can i use Arlo Pro if I don't have access to the router?
Is it possible to connect the base station to the internt via secure wifi? I don't have direct access to the router. What are my options?
Without direct acces to the router to plug in an ethernet cable for the base you can ;
1) use a wif extender ( would need the PW/SSID of the primary router ) with an ethernet port to plug into ( you also need a 1Mbs upload min )
2) use a wifi hotspot that same way if it has a port, tho of course data charges would apply
