Please offer real answers and not just guess!
This can be accomplished as TomMac suggests above. Create a custom mode with custom rules instructing the siren feature to trigger on motion. After that, set your schedule to include the custom mode for the desired times.
For instructions on how to create a custom mode, see here: How do I create a mode with different rules for each Arlo Wire-Free or Arlo Pro Wire-Free camera?
IF you have armed the Pro AND and also set the Alarm in the mode , when the camera detects motion the alarm will go off....
You can use this MODE in the schedule so recording and alarm only happen during certain hours.
You can't set it at certain times. It's set for all day only.
Sorry, your prob just not setting the schedule correctly.... you can set modes multi times per day
THAT'S The main feature of the schedule, if you could only use ONE mode per day you wouldn't need the schedule
