yes you can, up to 120 seconds....
Go to Mode
Armed, hit > to edit
Camera then Edit
Record Video, hit >
Change the time slider
Hit the Back button on top left screen
Scroll all the way down to the bottom for SAVE
As a PS, once you learn the Mode editing, you should create a CUSTOM mode that copies the one your using so you don't mess up the default ARMED
Go to Mode
Camera then Edit
Record Video, hit >
