  • 1 Reply
  • 1286 Views
Daniel_NL
I have been considering using some form of solar panel to keep a Pro camera charged as it is mounted in a location that is tricky to reach. But the new Arlo Ultra solar panel is much cheaper than the older solar panel in my local stores, and the Ultra solar panel seems to have better cables and connectors. As far as I understand they are all equipped with micro USB connectors so it should be possible to use?
brh
@Daniel_NL,
The two solar panels are totally different. The cable at the panel end of the Ultra solar panel is built in and non-removeable and the camera end of the cable does not use a microUSB cable, but rather a magnetic connector. All of this is to prevent moisture entering the camera and panel.
Brian
