Can I set up to store cvr on my usb drive while the motion dectected video on cloud?
No. It's only on the cloud servers. You can use 3rd part software after the fact to screen capture the video as you watch it but that's the best you can do.
As a PS...
Remember that ONLY motion triggered recordings go to the usb drive... manual recordings do not
