7 Notifications for every 1
After one event the alto says I️ have seven.
After two, 14. After 3, 21 and so on. I️ have erased the app and redownloaded. Has anyone else had this happen? Thank you!
Try a browser to see if the same thing happens. If so, the fastest thing to do is to remove all devices in Settings, My Devices and start fresh. Use the Add Device button on the Devices tab to add the base and sync the cameras. Verify that all your firmware is up to date.
What phone, OS and OS version for each of your devices? Have you tried restarting his phone?
will try the restart. Thank you
Trixie65 wrote:
He has a 6 s +I️11.0.3
What about your phone?
Trixie65,
Is your husband using a shared account via the Grant Access feature or is he logging in using the primary account? Are you still seeing this behavior?
Trixie65,
Try removing him from the Grant Access list and send a new invitation link. After the new invitation is accepted, test again to see if you still get the same behavior.
