- Email to a Friend
Cam i take my cam battery always connected to an electrical socket (always) so don't need to recharge my battery? Or The cam must work only with the power of his battery?
- Email to a Friend
The Pro camera will work with the battery removed while using the adapter and cable alone.
You can also use the ac power cable/adapter with the battery in place and no harm will come to the battery.
- Email to a Friend
- Email to a Friend
Do you know if it would still be waterproof if the charging cable is permanently connected?
- Email to a Friend
The current cable is NOT rated for out side. But if you wanted to take silcon sealant in hand it may be possible ( just might loose warranty )
What I see as the problem area in the cable is at the adapter end re weather
