  • 1 Reply
  • 3304 Views
azi
 connect the base to my routor . no empty espace for eternet cale conection ,
Arlo base and mybroutor both have USB 1 and 2 port.
can i connect base to router for internet accsess by the USB CAble insted of
Eternet cable.
Alan
No. Any easy and cheap solution is a 4 port switch ($20 or less) to provide expansion capability. Remove at least one cable, plug the switch into that position and use the other ports to expand your network.
