Can I add an Arlo Pro to my existing Arlo system?
  • 8 Replies
  • 7484 Views
  • 2 Likes
  • 8 In Conversation
Bjorken
Recently I purchased an Arlo system. It would create an extra value to have an Arlo Pro in at least one of the areas. Can I just add an Arlo Pro to the system I alredy have i.e. can I use the same router?
Bjorken,
Yes, the Arlo Pro is backward compatible with the Arlo Wire-Free base station.
8 REPLIES 8
Bjorken,
MichaelChatt007
I have an Arlo system installed with 8 Arlo cameras and 3 Arlo Q cameras. I'm planning to add a Smartthings system very soon.  What am I giving up if I use the new Arlo Pro cameras with my 6 month old base station? Can I use the entire system and new Arlo plus cameras with the Smartthings environment? Or is the new offering an Arlo based alternative to the Smartthings solution?
Read the documentation and FAQs on the Pro - most info is available there.
The extra features of the Pro are said to not be available if you use a Pro on an old base station - the siren and the USB capability.
keithws
Netgear, please update the old Arlo base station to support the USB local storage option. I'd be more likely to expand my system with more camera's with USB local storage.
Barbhamill
Will i still get the benifit of the quicker (better) motion detction of the pro,  and does the pro have a greater range of detection or does it just trigger quicker?
Are you asking about using a Pro on an original base?  If so, any feature of the Pro camera will work fine.  The features of the base will not be available - that requires the Pro base. So, the answer to your questions is yes, yes and yes.
TeamRedbirds
Just installed our Arlo cameras yesterday. We've never has security cameras before so we are new to this.  Does anyone know if you add a 3rd camera can you add an Arlo Pro camera to a system that is running the regular Arlo cameras?
Mike
manfredz
Hero
Hero
Adding an Arlo Pro to a regular arlo system or visa versa is no problem
