Recent iOS App 2.4.2 Update Bug?
Did a restart on Base today using the App twice since the first time it throws an Offline msg. both of my Pro cams not coming back on normally.. Second time, it came out ok at first but suddenly every few seconds it continually doing the loop of restart.. I exited the App for a minute and come back.. It was all good again.. Hope there's a fix someday..
JPC,
What do you mean when you say it continually restarts? Are you saying after rebooting the base station it continued to reboot?
Yes, It continually doing the loop after doing the second restart on the App .. The Base Station however was just normal in solid green.. I think the problem I notice is the delay response between the App and Base... It seems it throws everything off when doing more than 1 reboot to the system.. Exiting the App usually fixes it..
