  • 1 Reply
  • 693 Views
Kaygee7
Last night wifi went off. It went back on, but since then I am not getting any recordings. I can view live but no recordings. Can anyone help?
DannyBearAgain
Are you able to make a manual recording while you live stream the camera?
If so will that recording show up in the app library and play ok?
Do you get push notifications from the camera if you motion trigger the camera?
