I have 3 cameras set up and only one seems to be capturing movement. All are working and the live video feed is great but no notifications for 2 out of the 3 cameras. The one camera that is sending notifications is working great. All sensitivity on cameras is 100%, volume 100% and charged 85%. What is the issue?
Can you make manual recording from the problem cameras?
Are you just missing the notifications, but getting the motion recordings?
I’m not getting notifications or motion recordings only live feed and manual recordings.
Ok. Have you looked in the mode, and make sure the rule for the camera is there?
The mode says that all cameras are active for motion. The cameras are brand new as I just bought and set up 5 days ago. Maybe I missed something in set up for those cameras. However I did the exact same step by step for each camera during installation
Have you tried running the motion detection test on the camera? https://kb.arlo.com/1114344/How-do-I-use-the-motion-detection-test-for-my-Arlo-device
Have you tried to remove & reinstall the camera(s) within the app, then reboot the base station?f
