Camera won't recognize battery. All I get is flashing amber light. Works fine on different camera.
  • 2 Replies
  • 2633 Views
vickienova
One of my four cameras is not recognizing fully charged battery.  I tested the battery on a different camera and it works fine.  Tried a 2nd fully charged battery and it still won't work in camera.  All I get is a flashing amber light.  Won't let me sync.
I plugged in the camera and it works.  For some reason the camera is not recognizing a battery.
vickienova
yes it is an Arlo battery.  I tried numerous batteries that are working in other cameras, it was just that particular camera that wouldn't accept a battery.
After some research I ended up wiping the metal prongs in the camera with a slightly moist paper towel and that did the job.  Guess the connection was poor.
Is this an Arlo battery or 3rd party?
vickienova
