- 2
Hi, i am having issues with my cameras not recording, registering movement etc. My app is up to date. Is anyone else having these issues as i am not sure what to do?
Hi @ksss11
You can try to remove 1 camera from settings > My Devices > Re-Add it to see if this fixes the issue you are experiencing.
Yup, happening to me too. None of my cameras linked to the base station are recording. I am however getting motion detection alerts! I could even barely load my cameras for live view to see if it's working.
My cameras are hopeless. Never buying Arlo ever again. It seems to me that since Netgear sold this company they are out to ruin the service.
Both my Base Station and Arlo Q have stopped working now for no apparent reason. They occasionally decide to work, then just stop again. At the moment the base station is saying it is not connected to the internet. Who knows why because it was working perfectly well before and all my other devices are working.
Arlo Q will also not connect to WiFi.
8 of my Arlo Pro and Pro 2 have stopped recording. I rebooted and removed the batteries. Still does not record movement. I can access the camera and view live. What's going on?
have 6 cameras and they have stopped recording 1 by 1. When I tried to get help, I was asked to pay a $250 contract before they would help me. BS
@JoeT wrote:have 6 cameras and they have stopped recording 1 by 1. When I tried to get help, I was asked to pay a $250 contract before they would help me. BS
I have seen this several times here. It is a scam site that you contacted when you googled support. Arlo does not charge for support.
The real contact numbers are below on this page.
I shouldn't have to keep babysitting the cameras and their tempers. If I don't change anything, I shouldn't have to keep doing that. Now I have a problem resurfacing on random cameras-- battery says 25% and symbol is yellow...next minute says 25%, symbol red, and camera stops recording PERIOD like battery is at 0%, even though in Settings it still says 25%. What's up with this?
@SSK61 Where are you seeing an "X"? On the actual recordings, Live streaming or somewhere else.
@SSK61 wrote:
. On the right bottom corner next to the gear(settings) button there is a circle with how many videos it has recorded.
So this is the video library - so I don't think it is blocking recordings, instead I think you are having an issue with recording playback.
Since this is at the bottom of the camera image, it must be in the app - since the web browser has that circle at the top right.
What device are you using (Android or iOS)? Have you also checked my.arlo.com on a the PC?
It might be useful to post a screen shot.
@SSK61 wrote:
But it is not picking up movement to record anything either when the x is on there
If you are seeing an X on the main devices screen, then likely it is also telling you that the cameras are off-line.
When this happens, are you seeing it on all your cameras? Or just some? Also, is it affecting all the cameras on a given base, or is it affecting multiple bases?
We should not have to keep resetting these cameras! There are some of us have them on sketchy eaves.
- 2
