  • 4 Replies
  • 4626 Views
Missyrobinson
I have 2 cameras on the front of my house. One facing the street from the garage and one facing the front door. it also has some street view. My issue is the garage cam will pick up movement and start recording but as soon as the movement is spotted by the front door cam it starts recording and the garage cam stops even though the activity is still in view of This cam. This creates gaps in the activity being recorded is there any way to stop this or should I reposition the front door cam?
Can you lengthen the time alloted to the gargage cam?
Or do you have them as stacked cams where both record from one trigger ?
Pics may help
Missyrobinson
I can increase the time on the garage cam but it's currently set to record until motion stops. Which it's not following that rule. I read a few posts about camera trigger rules but I don't have those options in the app the set the cams to trigger all at once ect...
I recommend putting it on the max of 2 mins instead..there have been issue with the setting "till motion stops" in the past.
Missyrobinson
Lovely! Lol thanks I will do that instead.
