Camera not recording
I have tried changing and saving settinga multiple times with no luck.
It senses the motion and I have also just tried pulling battery then putting it back in.
Any thoughts?
Try removing the camera via the app, then resync it with the base station.....
I have the same problem with 1 out of 4 cameras. Tried the reset and still does not record all of the time. What next?
wacarring,
Are you running a schedule? Is the affected camera Armed when attempting to detect motion and record? Check your mode/rules to make sure there is a rule telling the affected camera to record upon detecting motion.
Same thing here. This morning all 4 didn't record anything. After a restart 3 starter working. Any solution to this? also no push notification.
JamesC - I use Armed mode all the time and everything is the way it always been.
serghe,
There was an issue affecting some iOS users that has since been resolved. Are you still seeing this behavior?
Please let us know,
No problems since then. All good for now.
