Camera not recording all movement
  • 12 Replies
  • 1343 Views
PocketPro15
My cameras are not recording all movement. Yesterday my front doorbell rang at 5:24pm and I was not able to answer it. When I went to my library to see who it was, there was no recording from either the doorbell camera nor another camera that can see the front door.
BrookeN
12 REPLIES 12
Can you verify which mode you're using when this happens? Have you checked the rules in that mode to ensure proper settings are there?
BrookeN
Can you please send a screenshot of what you have set up under modes for the cameras that are not recording?
PocketPro15
PocketPro15
I'm in the Arm Home setting. Here is the configuration for the front doorbell.Arm.Home.Front.Doorbell.Settings.jpg
PocketPro15
Front door settings. It also did not record.Arm.Home.Front.Door.Settings.jpg
BrookeN
PocketPro15
I have not but it's not the only camera having this issue.
BrookeN
Can you please dm me a callback number as well as a good time to call. That way I can have support look into this further. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
PocketPro15
Sent
BrookeN
Thank you for providing that information, I have reached out to support. They will be reaching out to you tomorrow per your request.
PocketPro15
They called on a day I wasn't available (not the day/time I requested). is there a number for support I can call?
BrookeN
There is:
US/CA Customers - 1-877-427-5680 6:00a.m. - 8:00p.m. PST
