have 2x Pro and 1x Pro2
For other reasons I had to reset internet/router, after that, the Pro 2 re-connects without any problem, but my 2x Pro's are still offline....
I have not yet re-started the base station.
Have read similar threads about the sync problems after power outage, but cannot figure out what should be the difference in sync of the Pro 2 and Pro.....!?
In any case, it should be possible to restart the base remotely ?
Since some cameras are working, your base is, too. Use Settings, My Devices, your base, Restart button at the bottom.
You can restart the base remotely but if the Pro cameras have been offline for a few days, they may have depleted their batteries. Is the system a long way away from you?
the re-boot did the trick - Thx.
