  • 2904 Views
Danmark
have 2x Pro and 1x Pro2
For other reasons I had to reset internet/router, after that, the Pro 2 re-connects without any problem, but my 2x Pro's are still offline....
I have not yet re-started the base station.
Have read similar threads about the sync problems after power outage, but cannot figure out what should be the difference in sync of the Pro 2 and Pro.....!?
In any case, it should be possible to restart the base remotely ?
Since some cameras are working, your base is, too. Use Settings, My Devices, your base, Restart button at the bottom.
steve_t
Master Master
You can restart the base remotely but if the Pro cameras have been offline for a few days, they may have depleted their batteries. Is the system a long way away from you?
Danmark
the re-boot did the trick - Thx.
