Hi everyone
I currently have an Arlo Pro,and I was thinking to buy a second camera, so that I can use one on the front and one on the back.
Just want to be sure what models I can buy that would easily pair with my current one? Would that be any advantages in buying a newer model (if it can be paired) that would make it worth it? Or do I just buy another Arlo Pro (as I am happy with it anyway)?
I'd stick with the Pro or Pro 2 since they would not require a subscription.
Thanks jguerdat, so you can confirm the Pro2 will pair with the Pro I have?
Yes, indeed.
