when sycing, the camera are practically in your hands, not out where people can see them
You did not specify which model of camera you are using. Ususlly the blinking blue led on the camera means that the camera is trying to sync with the base station if it is blinking slowly and a rapidly blinking blue led means that it has synced. It should go off after a couple of seconds once it has synced. Are your cameras working normally? You may have a range issue.
Brian
Since this is the Pro section, I'll go with that as the model. In Settings, My Devices, your camera is a Camera LED setting that allows you to turn the LED off. Is that the issue here?
But the blue led should not be flashing all the time, right?
Brian
the BLUE led does NOT flash all the time...
It is solid blue if the camera pack is fully charged and flashes during sync ( unless you have the motion test feature on then it may flash there, unsure what color )
Led can be toggled off.
( one exception is the Q cams, which whn place near the edge of wifi range, the led will flash blue/purpleish )
Normally, the LED is off, unless you are syncing and the battery toggle is off.... don;t understand the issue ??
I don't think you can turn the Led off for syncing or firmware updates. That is a safety feature to notify you not to turn off or open the battery door while these things are happening. But they usually only only last for a couple of minutes, so normally no one would pay any attention to it.
Brian
