I have 5 rental units that are part of a remodeled house. I am thinking of setting up 4 arlo pro cameras outside. Can system be set up so multiple users can check all cameras from cell phones? What if one of the users leaves the app on will it deplete batteries? Is there a time out for cameras?
Thx
Thx
If yoi have wirelese ones. The batteries will be depleted very quickly. You want them to activate if they detect movement. You can also share with other people but i haven't tried that yet.
The app/system will auto-shut down at the 30 min mark to prevent depleting batteries.
But , yes...more users the quicker the batteries will drain. Spec usage is 5 mins or less per day to obtain listed battery life.
