Battery won’t stay charged after I charge it
My battery won’t stay charged after I charge it. I noticed the lights on camera were staying on for a long time ? Any suggestions
Have you pull the battery and reinstalled ? ( or charged in camera )
A reset of the camera requires pulling the battery.
If the above doesn't work, you may have to Remove the camera from base ( remove device ) and then bring it back as if new. ( write down any customs modes you may have as removing will delete them and reset to default )
If still NG, it just may be a fault in the camera itself as with the LEDS on all the time, the battery will drain at a fast rate.
Try removing the camera from your account and then onboard it again. Any help?
