What is the expected Battery life in tempuratures like Arizona at 115 degrees in the summers? How often should I expect to have to recharge them and how often do you have to replace them at these tempuratures?
TBMK, that within op temps of the battery tho spec use of camera is to 113 F
with the size of the pack, it should run about 3 months in normal use
