he intentado todo por dos semanas para conectar la base a la app. , segui absolutamente todos los pasos, todas las opciones de reseteo de fabrica pero no es visible por la app. la base es nueva
I have tried everything for two weeks to connect the base to the app. , I followed absolutely all the steps, all the factory reset options but it is not visible by the app. the base is new
Message 1 of 4
952
Thanks for the feedback, do you mind providing the troubleshooting steps you have done so far.
Message 2 of 4
467
They will send god free another base station, I tried everything but there was impossible to match the hub with the app
Message 3 of 4
464
Thanks for the update.
Message 4 of 4
453
