  • 875 Views
Negrosantana
he intentado todo por dos semanas para conectar la base a la app. , segui absolutamente todos los pasos, todas las opciones de reseteo de fabrica pero no es visible por la app. la base es nueva
I have tried everything for two weeks to connect the base to the app. , I followed absolutely all the steps, all the factory reset options but it is not visible by the app. the base is new
ShayneS
Hi @Negrosantana
Thanks for the feedback, do you mind providing the troubleshooting steps you have done so far.
Negrosantana
They will send god free another base station, I tried everything but there was impossible to match the hub with the app
ShayneS
Thanks for the update.
