Base stays offline, All leds are green and it syncs with camera. I tried reset, and wire reconnect but it won,t go online
you are correct. while resetting I changed the base name. To fix it I had to remove the basevcompletely and re install it. Thanks
If all lights are green, it should be online. What makes you think the base station is offline?
