  • 2 Replies
  • 3381 Views
  • 2 Likes
kdb
Base stays offline, All leds are green and it syncs with camera. I tried reset, and wire reconnect but  it won,t go online
kdb
you are correct. while resetting I changed the base name. To fix it I had to remove the basevcompletely  and re install it. Thanks
steve_t
Master Master
If all lights are green, it should be online. What makes you think the base station is offline?
kdb
