Base Station Firmware Update Request Timeout
I'm having the same problem. I can't view a live image of my cameras because I need to update my base station firmware. I've tried multiple times, and after a few seconds, it pops back up saying I need to update my firmware. I've tried resetting my base and the app, but nothing is working. I think my cameras need the firmware update as well, but I can't do those until the base station updates, which it won't.
**UPDATE**
I tried to update the firmware via web computer browser vs. my iOS app, and after attempting, it gave a popup error saying: "base_station_error_4403". Not sure what that refers to, but I didn't get that warning on my app. From what I've read in other forums with this 4403 error, you need to physically reset the base station (and possibly your router as well) with a hard off/on reset. Resetting via the app doesn't seem to work. I'll have to check when I get home if this resolves the issue. Not a convenient way to run an update if multiple people have to physically reset it, instead of it just working...
I was able to get mine to update succesfully, but I had to do it twice. The first time I connected I saw a message where my cameras should be that said my firmware needed to be updated, let's start with the base. I clicked update, it prompted me to confirm, I clicked OK and then it started. I watched the window and it changed to "rebooting device" and then came back up and appeared to be done. When I tried to view my cameras, it kept saying error, connection failed. I logged off and on again, and again, I was prompted to update. I clicked update again, and after several minutes, it rebooted and this time the update was successful. A few minutes later my cameras came back online. What's a little odd to me, is why this just didn't occur automatically as it usually does? I have never had to click to manually update my base since I first bought the system years ago so that was odd to me.
Hey everyone,
Is anyone still experiencing some problems with updating the Base Station firmware? If so, you can try to update your Arlo firmware manually or wait between 3-5 am as automatic updates happen between that time to minimize camera downtime. If that still doesn't help, feel free to try to power cycle your Base Station.
Otherwise, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I have tried multiple times to update the firmware on my base station. I tried to open chat with Arlo Support and never got connected in 10 minutes of trying. I am about to rip these stupid things out. I have searched support and never found anything helpful.
Hey TK5728,
If you're unable to connect to the support team through live chat, feel free to give them a call or you can email to the support team with the link above. If you're having problems contacting them, feel free to let me know.
That solution never works !
