  • 1 Reply
  • 962 Views
Blake14m_a_c14
I have brought this product and tryed to set it up but the middle light won’t turn green what can I do?
Streak2
Master Master
Assuming that you have the base connected to your Internet router via Ethernet cable then try and restart your Internet router. You can also try and restart your base. The light being off means that your router is not seeing the base.
Also see here
https://kb.arlo.com/996/My-Arlo-base-station-is-offline-how-can-I-troubleshoot-it
Streak2
Master Master
Also see here
