Automatically turn off siren
  • 2 Replies
  • 3398 Views
oujoker
I have a smarthings leak detector that I have programmed to turn on siren and push a notification when triggered.  I would want the siren to stop at some point, however, if I cannot immediately remotely disable the siren.  Is there a timeout available.  That would be a good feature if not.
You can set the siren time in your modes. Not sure how that would work with ST.
brh
@oujoker
There are many ways to turn the siern on and off in Smaerrhings.
You could set up two scenes to manually turn the siren on and off if needed. You should be able to use the Smart Lighting app in the Marketplace and use the water leak sensor to trigger the siren You can create Custom Rules. etc.
Brian
