  • 5 Replies
  • 5404 Views
  • 3 Likes
TLCRoses
The Camera Positioning Mode and the Motion Detection Test both indicate Busy for one of the cameras -- the other three work just fine.  I'm not able to turn off those settings.  Clicking anywhere around those areas does nothing.  The camera will not connect to Live Mode, nor will it record.  I have tried removing the device, and re-adding, and  I have swapped batteries with another device.
5 REPLIES 5
try and restart the base by the power button ( off-on )
Geomol
Help!
My camera is stuck in positioning/motion detect busy mode. I have tried taking out bateeries (several times) replacing batteries (several times) switiching off base station, removong and reinstalling device several times. Still will not remove from the busy setting.any more suggestions.
That sounds like a display issue, not camera. Have you tried logging out and back in as well as using both a computer browser and the app?
Geomol
Thanks i think you are roight as the display on my phone app is OK. Need now to address the display on my ipad.
Thanks again for the suggestion.  Dan
Try rebooting the iPad and reinstalling the app.
