  • 1 Reply
  • 5819 Views
Flo123
Hello,
Just bought an arlo pro.The big problem is that in schedule mode I can only input from 00.00 .
For example I leave the office at 21 pm and come back at 9 am.
When I try to set this hours interval it gives me only the possibilty to start from 00.00. So 3 hours the notification and the sire are off.
Is very frustating because I found the schedule mode the best for me.
Any help will be higly appreciated
Thank you
SallyC
Arlo doesn't allow you to schedule past midnight into the next day.  So you'll want to create two schedules - one from 21:00-23:59 and one from 00:00-9:00.    You can also select whatever Mode you want for that schedule so if you have a custom Mode (e.g., camera 1 sound only) you can select that in your Schedule.  Just create the Mode before you create the schedules.
To set a schedule for a camera:
  1. Launch the Arlo app or log in to your Arlo account at arlo.netgear.com.
  2. Click or tap Mode.
  3. Click or tap a camera.
    A list of available modes displays.
  4. Click or tap Schedule.
  5. Click or tap Edit next to Schedule.
    The Add Schedule page displays.
  6. Click or tap + Add.
  7. Set the days and times for your new schedule.
  8. Click or tap Save.
    Your new schedule is saved.
SallyC
