Sensitivity
  • 1 Reply
  • 3700 Views
makurow
I can't find how to set sensitivity. There is a place in settings defaulted to 50%, no changes I make there stick. Help. All access through Android app.
The sense levels you want to adjust are in the MODE you are using ( prob ARMED )
you have to edit the mode
Check the FAQs for sense levels
basic info;
Edit the recording mode (probably ARMED) and edit the rule for that camera. Next to "Motion is detected" there is either a pencil or a > symbol. Click that. A slide with appear with the sensitivity. It's probably on 80. You'll have to experiment with it to get to the right setting. After you change it, click back. Then scroll down and click SAVE. Don't forget to save or the sensitivity won't change
basic info;
