Arlo shows offline. Tried disconnecting router and then Base Station but still shows offline
  • 11 Replies
  • 3122 Views
Verneta
Hello , my Arlo says it’s offline and I’ve done the disconnect the router then the base !! But it’s still not working ; any suggestions ? Thank You
11 REPLIES 11
Not sure what you mean by "disconnect" - turned them off and back on? What are the LEDs on the base showing?
mdelacuevam
I'm having the same trouble, the app shows a offline base station, the internet ligh is solid green, the power is solid green and the camera lighs is solid ambar, any suggestion?
The solid amber Camera LED means the base needs to be claimed. Try using the Add Devices button on the Devices tab to claim it again.
Verneta
I went n grabbed one of my cameras thinking I’d restart the entire thing but the camera is supposed to flash blue but it’s flashing amber
Verneta
Grabbed one of the cameras n it’s showing amber not blue !! It says to start over : per the instructions my phone has discovered the base station but camera flashes amber
Verneta
I turned the router off then unplugging base station . Then turned back on router n waiting for a complete reboot ! Router rebooted then turned on base station ! Camera still showing amber
Verneta
The problem seems to be with the base station : I tried to reboot the base station but no go !!! It’s a red circle with an X !!! Everything is as it should be ???
If the camera LED is flashing amber, it's alow/dead battery. Flashing amber for the Camera LED on the base means poor WiFi connection.
Qjhn
Same thing. Support links put me in a cycle. No help from company
mdelacuevam
It worked, it took me a while because the cameras aren’t easily accessible, I had erase the base station and then do the whole thing as if they where new, but everything is working now, thanks.
Contact support link at the bottom here and again on the 2nd page. the 3rd page has contact info:
