Here is what I did yesterday and so far it appears to have fixed things.
Removed the batteries from all of the cameras
Factory reset the base station
Set everything up as new
Try reboot the base and reinserting the camera battery to reset to a known condition. Also bring the camera closer to the base to see if that makes a difference.
If you really want to reset the system you should remove all devices ion Settings, My Devices. If you then want to use the reset button, it's like virtually all reset buttons - you have to hold it in for at least 10 seconds. The LEDs will flash amber. Let it reboot and start rebuilding the system by claiming the base first and then syncing the cameras.
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
