Here is what I did yesterday and so far it appears to have fixed things.
Removed the batteries from all of the cameras
Factory reset the base station
Set everything up as new
Try reboot the base and reinserting the camera battery to reset to a known condition. Also bring the camera closer to the base to see if that makes a difference.
If you really want to reset the system you should remove all devices ion Settings, My Devices. If you then want to use the reset button, it's like virtually all reset buttons - you have to hold it in for at least 10 seconds. The LEDs will flash amber. Let it reboot and start rebuilding the system by claiming the base first and then syncing the cameras.
