Arlo pro + solar panel outdoor mount solution
  • 1 Reply
  • 786 Views
Angdema
Is there a specific outdoor mount designed for the arlo pro that accomidates the use of the solar panel. Currently the 90 degree micro adapter supplied with the solar panel is obstructed by the adjustable mount.
migman_2001
Luminary
Luminary
supposedly you can call Netgear and they will send a replacement. Or do like I did, just remove it. The camera mounts and tightens just fine without it.
Good luck.
