What is the problem?
If you are on the Basic Level ( free ) of service...Only 5 cameras are allowed.
If not, pull battery to reset camera, attempt again and use only a quick push on the base sync button
Did you buy the 6 camera package? If so, you're allowed 6 cameras. Try again following what @TomMac said.
If you didn't buy the 6 camera pack you're only allowed 5 on the free plan. To add more than 5 you have to pay a monthly or yearly fee.
https://www.arlo.com/en-us/products/subscription-plans.aspx
Did you try pulling the battery on the 6th camera, wait a few seconds, put it back in, and try to sync again?
Can you be more specific about the inability to use the 6th camera? Is it that it doesn't sync or that it syncs but you can't use it? The 6 camera sets are special sets and you have to use the specific code/SKU when first installing to gain access to all 6.
You shouldn't have to pay since you bought the 6 camera set. If you used the correct code to be allowed to use 6 and you can't get that 6th one working you might want to open a case with support and see if they can sort it out for you.
Just an FYI, since you already have the system set up, you may have an issue if you didn't select the proper system. As I understand it, you'd have to remove all devices from Settings, My Devices in the current account and then use a second email address to correctly set up the system so all cameras can be used. I may well be wrong on this but at the very least you need to start fresh after removing all devices. Of course, this is for the 6 camera systems.
