Since the last update by Arlo was pushed through I am not getting alerts on my Android phone. I have contacted support several times, still not resolved. If I do get an alert on my phone is delayed up to 1/2 hour! I have seen other comments about this from other consumers, Has anyone else had a resolution? I am paying for a service that I am not recieving!!
I am assuming your notifiations on your are on since you tie this to an update. Unsure what you have tried, but the first thing is to go to Settings>Apps>Arlo>Permissions>and make sure that "Phone" is toggled on. Both Microphone and Phone should have permissions with the Arlo app.
I had a similar problem with my Android phone (Google Pixel 3), which I just solved today. The problem for me was that the latest version of the app apparently decided that the default notification preferences should be "silent"...so I didn't know I was getting notifications until I got another notification from some other app and I noticed there were half a dozen notifications from Arlo that never popped up.
I don't know about the differences between android versions, but I have the latest from Google, so here's where the setting was located for me:
Settings -> Apps & notifications -> Arlo -> Notifications
When notifications are turned on, there are two checkboxes: "Always Listening" and "Notifications" (both were already checked)
Tap on the word "Notifications" (not the checkbox, the WORD) - this brings up additional settings, including a "Behavior" option.
The latest version set the "behavior" to "Show Silently"...I just changed it to "Make sound and pop on screen", and now my notifications are working like they used to.
You may also need to do the same thing with the "Always Listening" behavior...
Hope this helps.
The latest Android app takes you straight there if you try to set the notification sound in Settings.
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
