Hi,
I'm interested in getting my first Arlo Pro but I have 1 major issue - I use a 4G box instead of a router and therefore do not have an ethernet connection. This means I can't connect the hub.
I'm going to try use a wifi extender to convert the wifi signal into an ethernet output but as the 4G box doesn't have a WPS button this may be impossible. Another option is to buy a Mi-Fi box with an ethernet output but these are expensive.
Can anyone think of a workaround for this problem?
I've just downloaded the arlo app and at the bottom of the Arlo product set-up list is 'Arlo Wire-free with Mobile Router' - is anyone awae of what this is?
Lastly, is it possible to control the delay between motioned being detected and the alarm setting off? And can the length of time the alarm sounds for be limited?
Thanks - I'll give either one of these solutions a go and get back to you!
You should be able to connect your device to the wifi extender and then use that to configure the extender to connect to your 4G router's wifi.
Not sure about the Connect to Mobile Router setting. Would be interested to find out. Perhaps @JamesC might know more about this option
No delay that I know of
https://www.netgear.com/home/products/connected-entertainment/gaming-home-theater/wnce4004.aspx
I use one for a different purpose and its effective.
You would connect it to the base station.
BTW, with any WiFi extender you should be able to connect it to your WiFi without the use of WPS. There should be instructions with the extender as to how to do this which essentially means you would connect the the extender's WiFi signal, configure it and then connect back to your usual WiFi.
