tonylock83,
Yes, Arlo Pro cameras are weatherproof by design. For more information on this, take a look here: Are Arlo Pro Wire-Free cameras weatherproof?
While anything's possible, I've had mine outside since the beginning. While they're typically somewhat protected, being under eaves, they've been blasted by wind, rain, snow, fog with few issues. I do get water droplets on occasion which certainly affects video quality but it's rare. Just make sure your battery covers are properly closed and not cocked.
tonylock83,
"However, Arlo Pro AC power adapters and adapter cables are not weatherproof."
So really, they are not 100% weatherproof.
If they were 100% weatherproof, the micro usb connection would be sealed when the cable was connected.
Many of us have "modified" the connector with silicone or mastic tape if we want to power 100% by AC power.
This was a poor oversight when designing the pro especially since that was a feature many of us were asking for instead of modifying the battery compartment on the original Arlo with alligator clips etc.
DaveWoj,
If you would like to use your Arlo Pro outdoors with a power adapter, take a look at this option for powering outdoors: Outdoor Power Adapter (VMA4700)
Yes, that is an option and possibly a solution.
Unfortunately, I am unable to comment on or recommend an accessory that doesn't exist.
