Ok tried everything that I read and could think of over and over ...no luck
Then I tried turning off Night Vision (in Video Settings) went back to motion detection test
and what do you know ! the amber light was flashing again !!!
Now the camera works fine ... and I was just about to buy a new one
Good luck
Hello
Yes the camera works fine now.. yes it did go back on
I tell you I tried all day ! every reboot, restart, start fresh, move the camera around , tried in the dark...etc etc.
On/off switch, removed everything, put it back in box and start fresh ! (just kidding)
Then for the hell of it I turned of night vision as that was the only thing I didn't try...and whala motion amber light started to work..went in and turned night vision back on and all works fine now
alexitos,
Night Vision being on/off should not have any impact on the motion detection test. Are you able to turn Night Vision back on? Does the camera still detect motion?
Hello
