Nothing has changed in my settings. The microphone and speaker are still on. Nothing has changed in my phone permissions. The little icon just disappeared.
I tried rebooting the system. Checking for and upgrade and powering the mics on and off but it didn't work.
Please advise.
I closed app and signed back in, no good. Deleted app, shut down phone, rebootted and reinstalled app. works fine--thanks!
still not see it, I have rebooted my phone still no Mic ?
1) Delete the app.
2) Hard reset your iPhone (- volume and power button for iPhone 7 and home + power butten for older version)
3) reinstall the app.
These steps works with me.
Sorry i try everything
Delete my app
Delete my cameras and reboot all my things ...
Not working !
What i should do
I went to setting from the app and log out
Try to login and it still not working ...
I turn off the cameras and turned on;
Nothing...
Do i hAve to download an update???
Maria
Bernitarantini,
Logging out of the app and signing back in should resolve this issue. Are you experiencing the microphone not displaying at all or a different issue?
See if there's any updates on your phone carrier and your iOS/Android by restarting/rebooting it.. see if that helps
- Yes nothing is working.
And second i will try to reboot my phone and there is something wrong on and it is not making working good
Because i try it all and nothing!
So let's try the last thing...
Bernitarantini, Rderosa
Be sure you are logging out by navigating to Settings > Profile > Log out. Enter your password information and log back in.
This should restore the microphone icon.
Logged out and logged back in still no microphone display. Is there something else we can try?
Thanks.
Chil wrote:Logged out and logged back in still no microphone display. Is there something else we can try?
Thanks.
Have you tried un-installing App and re-install? Try it see if it helps.. Restart your Phone..
First thanks for the tips
- i delete the cameras from my app
- logged out
- delete the app
- Restart my iphone
<><><><><><> After that <><><><><><>
•Fix my phone
•Download the app again
•Logging
•Restart and sync cameras
Then just in case i restart one more time my iphone and after that iget in the App and it get fixed
So i figure out i had to log out , delete everything & restart the phone and after that reintall everything and it works !
My mic is back!
Thanks to all for the help
Sherryncrew,
Log out by navigating to Settings > Profile > Log out. Enter your password information and log back in.
HAPPY TO SAY IT IS NOW WORKING BUT I HAD TO UNINSTALL THE APP ON MY IPHONE 7 AND REINSTALL TO MAKE IT WORK.
I logged out and back in and microphone is still gray.
Try reinstalling the app.
Remove and reinstall fixed the microphone missing issue.
I hope Arlo can have a better testing before releasing the new software.
This may have happend at the same time I got my Echo Show and linked the 2 accounts.... Hope this helps
It is STILL not working 1 month later.
MillieHa,
